Dankest Vex Memes?
woke up in the middle of the night with the idea. I knew it would be gone by morning unless i acted.
After days and nights, I did it. I earned…
… Is that a good thing?
what are the qualifications to get regular?
When Alliance for money gets 27 replies in 2 hours:
Its an interesting topic, unlike the random Chit-Chat / Rumor Mill threads that show up.
We had an interesting discussion yesterday during practice:
Would you rather not have bearing floats or shaft collars on your robot?
  • No bearing flats
  • No shaft collars
0 voters
The forums are being used greatly for the intended purpose of forums. Don’t be so silly
No Bearing flats causes slop, while no shaft collars can be solved by spacers.
but the axle would slide out of the shaft collars and spacers
Unless you had a physical stop to stop the shaft from sliding.
@9MotorGang very true
what we are missing is that no bearing flats means only screw joints
but its only 12
20char
You could drill out inside linear slide rail to act as a bearing.
Okay, but how about this:
Would you rather only have rubber shaft collars, or only be able to use steel?
  • Rubber Shaft Collars
  • Steel, baby!
  • This is an idiotic question. I did both my rookie year.
0 voters
time to create my new and impaired bouncy ball
featuring: vast quantity’s of rub nubs
rubber shaft collars don’t exist in my school, are they worth buying?
  • I should add rubber shaft collars to the needed parts list
  • I should only buy more steel shaft collars
0 voters
and to keep the thread on track
