Time to make it 3. ![]()
shame
dude i need the model for that
I’m going to print it as a whole ring instead of halves and if that works I’ll send it to you.
thanks man! thisistofillupthetwentycharcaterlimit
The workcell rack is out of stock, so don’t get too excited.
that’s why turning down a call from it would be such a foolish choice.
Could you send this to me too, thanks!
Shouldn’t SG3 be behind G13, G14, and G3?
Not sure the best spot to post this, but I knew it needed to be posted somewhere.
Video credit to @Paul_Humphrey
Here is the stl for dwane the ring johnson. Print it with supports (set supports to everywhere), raft isn’t necessary but you can use one if you want to, 0.2 layer height is what i used and it looked perfect and only took 7 1/2 hours dwane the ring johnson.stl (1.1 MB)
POV: you lose in finals by literaly 1 ring thats in a moblie goal on your side
I’m printing this. now.
when you know that your robot is gonna fail because it has bad quality work but ends up working way better than expected.
POV: when your robot broke 5 mins before your match so you fix it as fast as you can and you expect it to break mid-match but it does better that before
When your in 15th plce and first seed picks you, despite having ignored you the entire competition
