What are of the advantages and disadvantages of connecting wheels directly to motor? I am thinking to connect 600rpm directly to 3.25 or 4in wheel and drive at a reduced rpm via code?
Reducing the speed in the code causes you to just lose wattage, meaning you’ll drive slower, but not gain the additional torque a gear ratio would give you. So running 600 on 3.25 or 4 would have awful acceleration, equivalent to running it at max speed.
Decreasing RPM in code reduces power as well. Gear ratios retain the full power of the motor while still decreasing the RPM, which allows you to have full torque.
As @Brayden21510R said, connecting a 600 rpm motor to any wheel size >2.75" will result in pretty insane speeds, and insanely awful torque.
Reducing the speed via code does nothing to affect the torque (which affects acceleration and pushing power). Your drivetrain will have roughly the same acceleration and pushing power (which are awful for such a speedy gear ratio) as if it were at full speed.
I recently made a post about the difference between reducing the speed via code and using different gear ratios:
This is very helpful. Thanks.
You can do green cartridge motors (360 rpm I think?) direct driven to 4in wheels. this is a little too slow to be highly competitive with (41.8 in/sec, average for vex bots is typically ~60), but is good enough for beginners since it’s ridiculously easy, allowing you to focus on the rest of your robot. Alternatively, I’ve made a list of easy drive gearings that you could use, just know that they’re designed to be used with 6-motor drivetrains.
