Flywheel Speed Consistent
Hey guys I have a question. Me and my team have been having this problem where our flywheel speed does not stay consistent. If anybody has suggestions please reply.
Please look at other topics before creating your own. There have been several similar questions in the past few days.
Flywheel Speed Fluctuating
Non-smooth flywheel
If you are running under the maximum rpm, control the motor speed using voltage instead of trying to set the RPM.
If your using vexvode v5 pro it looks something like this:
Flywheel1.spin(directionType::fwd, 0 - 12, volt);
if you guys are using velocity try switching to voltage in your code. my team was having the same problem and it worked for us
our code looks like this
if(Controller1.ButtonR1.pressing()){
shooter.spin(vex::directionType::fwd,X,vex::voltageUnits::volt);
X can range anywhere from 0-12 where 0 is 0% velocity and 12 is 100% velocity
if you want to convert percent to velocity all you have to do is multiply 12 by the decimal form of the percent you want
for example if you wanted to run the motor at 80% velocity you would do 12*.8 which is 9.6 volts. so you would replace the X in the code for 9.6
