I was asked a couple of day ago about how to draw graphs on the V5 screen, presumably to help with PID tuning and things like that. I’m sure there are some comprehensive libraries available in C or C++ that could be easily ported, but for simple visualization of motor velocity and variables it can be quite easy using the normal drawing commands that VEXcode has. Here’s a little demo that draws and scrolls simple data.
and the code that was used to do that.
graph demo Code
/* Module: main.cpp */
/* Author: james */
/* Created: Fri Mar 20 2020 */
/* Description: V5 project */
#include "vex.h"
#include <vector>
using namespace vex;
// A global instance of vex::brain used for printing to the V5 brain screen
vex::brain Brain;
class graph {
#define NUM_POINTS 480
private:
// class to hold points for a single graph line
class points {
public:
uint32_t *_points;
vex::brain::lcd &_screen;
vex::color _color;
points( vex::brain::lcd &screen ) : _screen(screen) {
// allocate memory on heap
_points = new uint32_t[NUM_POINTS];
// init everything to some value we consider invalid
for(int i=0;i<NUM_POINTS;i++) {
_points[i] = INT32_MAX;
// default line color
_color = vex::white;
~points(){
// deallocate memory
delete _points;
// draw the line
// There's a variety of ways to do this, could be another property of the class
void draw() {
_screen.setPenColor( _color );
for(int x=0;x<NUM_POINTS-2;x++) {
if( _points[x] != INT32_MAX ) {
_screen.drawLine( x, _points[x], x+1, _points[x+1]);
_screen.drawCircle( x, _points[x], 2, _color );
// add a point to this line
void addPoint( int value ) {
for(int i=0;i<NUM_POINTS-1;i++) {
_points[i] = _points[i+1];
_points[NUM_POINTS-1 ] = value;
// set color for this line
void setColor( vex::color c ) {
_color = c;
public:
vex::brain _brain;
std::vector<graph::points *> _points;
int _origin_x;
int _origin_y;
graph( int seqnum, int origin_x, int origin_y ) : _origin_x(origin_x), _origin_y(origin_y) {
// allocate and store each line
for( int i=0;i<seqnum;i++ ) {
_points.push_back( new graph::points(_brain.Screen) );
// thread to render this graph
thread( render, static_cast<void *>(this) );
~graph(){
// we should deallocate the vector members here really
// Thread that constantly draws all lines
static int render(void *arg ) {
if( arg == NULL)
return(0);
graph *instance = static_cast<graph *>(arg);
while( 1) {
// this will call render, no need for any other delays
instance->draw();
return(0);
// Draw graph X and Y axis
// modify to fit your needs
void drawAxis() {
_brain.Screen.setPenColor( vex::white );
_brain.Screen.drawLine( _origin_x, 0, _origin_x, 240 );
_brain.Screen.drawLine( 0, _origin_y, 480, _origin_y );
for( int x=0;x<480;x+=20 ) {
_brain.Screen.drawLine( x, _origin_y+5, x, _origin_y-5 );
for( int y=0;y<240;y+=20 ) {
_brain.Screen.drawLine( _origin_x+5, y, _origin_x-5, y );
// draw everything
void draw() {
_brain.Screen.clearScreen( vex::color(0x202020) );
drawAxis();
for(int id=0;id<_points.size();id++)
_points[id]->draw();
_brain.Screen.render();
// add a point to a particular sequence
void addPoint( int id, int value ) {
if( id < _points.size() )
_points[id]->addPoint(value + _origin_y );
// set the color of this sequence
void setColor( int id, vex::color c ) {
_points[id]->setColor( c );
int sinTask1( void *arg ) {
if( arg == NULL ) return 0;
graph *g = static_cast<graph *>(arg);
int x = 0;
while(1) {
g->addPoint( 0, sin( x / 180.0 * 3.141) * 100 );
if( x++ == 360 )
x = 0;
this_thread::sleep_for(20);
int sinTask2( void *arg ) {
int x = 180;
while(1) {
g->addPoint( 1, sin( x / 180.0 * 3.141) * 50 );
if( x++ == 360 )
x = 0;
this_thread::sleep_for(10);
int cosTask1( void *arg ) {
int x = 180;
while(1) {
g->addPoint( 2, cos( x / 180.0 * 3.141) * 50 );
if( x++ == 360 )
x = 0;
this_thread::sleep_for(15);
int triangleTask1( void *arg ) {
int y = 0;
int inc = 1;
while(1) {
g->addPoint( 3, y );
if( abs(y+=inc) == 80 ) {
inc = -inc;
this_thread::sleep_for(5);
int main() {
// 4 lines, axis at position 120, 120
graph g( 4, 120, 120 );
// set line colors
g.setColor(0, vex::color::white );
g.setColor(1, vex::color::red );
g.setColor(2, vex::color::blue );
g.setColor(3, vex::color::green );
// and we are using separate tasks to add points to each line, this is a bit overkill
thread t1( sinTask1, static_cast<void *>(&g) );
thread t2( sinTask2, static_cast<void *>(&g) );
thread t3( cosTask1, static_cast<void *>(&g) );
thread t4( triangleTask1, static_cast<void *>(&g) );
while(1) {
It could actually be a little simpler than I show, no need to use a thread for each graph line really, all you need to do is create the graph instance and then decide how and when to add values for each line it draws. This graph scrolls as values are added, but obviously you could modify the code and just create static graphs. There’s also no scaling of data (it’s just using pixel resolution) but, again, that could easily be added.
The code also demonstrates one or two other more advanced techniques, it uses dynamic memory allocation for the data storage, it passes an object to each thread, and it uses a thread in the graph class that can be shared amongst several instances (although that wouldn’t make much sense in this case as graph drawing clears the screen each time)
