Harvard-Westlake Robotics: AMOGO x DOGO Reveal
The mogo lift motor was overheated. I also encountered the same problem. I checked it and increased the rubber tension, but it didn’t solve it. It is suspected to be the procedure. Repeatedly feeding the motor current. Can anyone help?
Make sure you are using the red motor cartridge (100 rpm).
When you turn the robot on, make sure the mobile goal lifts are all the way collapsed into the robot. The little bit of power that the motors get shouldn’t be enough to overheat it, unless that little bit is actually a lot because of the incorrect starting of the mechanism.
Hi!
I’m basically completely new to this so sorry if it a dumb question, but I wanted to know what I should use to view the Amogo Stp file that that Cad link take me to; so I can get a better view of the(for lack of better words) inside front intake area.
Thanks!
You can use almost any 3D viewing/cad software, such as inventor, fusion 360, or onshape. I may be wrong about this but you may even be able to upload this to tinkercad.
I know that this is unrelated to the topic but how do you get vex parts on autodesk inventor?
The vex website has cad files, just go to the product and scroll down to cad
It is strongly advised you use the cad library here for inventor.
