How to code a Rotation Sensor
Hello, I am new to coding and my team wants to use a Rotation sensor for our Lady Brown. I don’t know how to code it and need much help as possible from you guys. I wanted it to normal toggle for buttons A and B, and when I press button Y the Lady brown should go to those degrees for scoring position. I use Vex Pros c++ so if you could help me code this, it would be greatly appreciated.
You’re new to coding, and you’re using PROS? Use blocks. Or make someone else on your team code (if they have more experience).
Programming Language Used - VEX V5 General Discussion - VEX Forum:
@turbodog, @Foster, and @BananaPi recommend blocks for beginners.
Anyways, have you actually tried coding the Lady Brown and the Rotation Sensor? If you have, please share your code. If not, check out PROS API and write some code.
No like I ment I’m new to pros and don’t know how to code a rotation sensor
What’s the situation now?
