Legacy EDR for Beginners
I assume these are cortex brains and not the even older pic systems.
The “default” code provided by VEX can be downloaded by the old cortex firmware utility, however, RobotC includes as a sample program that is a close approximation of that default code. here it is if you cannot find it.
ROBOTC VEX Cortex Default.c
#pragma config(Sensor, in1,    ana1,                sensorPotentiometer)
#pragma config(Sensor, in2,    ana2,                sensorPotentiometer)
#pragma config(Sensor, in3,    ana3,                sensorPotentiometer)
#pragma config(Sensor, in4,    ana4,                sensorPotentiometer)
#pragma config(Sensor, in5,    ana5,                sensorPotentiometer)
#pragma config(Sensor, in6,    ana6,                sensorPotentiometer)
#pragma config(Sensor, in7,    ana7,                sensorPotentiometer)
#pragma config(Sensor, in8,    ana8,                sensorPotentiometer)
#pragma config(Sensor, dgtl1,  jmp1,                sensorTouch)
#pragma config(Sensor, dgtl2,  jmp2,                sensorTouch)
#pragma config(Sensor, dgtl3,  jmp3,                sensorTouch)
#pragma config(Sensor, dgtl4,  jmp4,                sensorTouch)
#pragma config(Sensor, dgtl5,  jmp5,                sensorTouch)
#pragma config(Sensor, dgtl6,  jmp6,                sensorTouch)
#pragma config(Sensor, dgtl7,  jmp7,                sensorTouch)
#pragma config(Sensor, dgtl8,  jmp8,                sensorTouch)
#pragma config(Sensor, dgtl9,  jmp9,                sensorTouch)
#pragma config(Sensor, dgtl10, jmp10,               sensorTouch)
#pragma config(Sensor, dgtl11, jmp11,               sensorTouch)
#pragma config(Sensor, dgtl12, jmp12,               sensorTouch)
#pragma config(Motor,  port1,           LeftDrive1,    tmotorNormal, openLoop)
#pragma config(Motor,  port2,           LeftDrive2,    tmotorNormal, openLoop)
#pragma config(Motor,  port3,           LeftDrive3,    tmotorNormal, openLoop)
#pragma config(Motor,  port4,           RightDrive4,   tmotorNormal, openLoop)
#pragma config(Motor,  port5,           RightDrive5,   tmotorNormal, openLoop)
#pragma config(Motor,  port6,           Mech1,         tmotorNormal, openLoop)
#pragma config(Motor,  port7,           Mech2,         tmotorNormal, openLoop)
#pragma config(Motor,  port8,           Mech3,         tmotorNormal, openLoop)
#pragma config(Motor,  port9,           Mech4,         tmotorNormal, openLoop)
#pragma config(Motor,  port10,          RightDrive10,  tmotorNormal, openLoop)
// Motors by default: + CW, - CCW
// Jumper IN  = 1 (touch)
// Jumper OUT = 0 (touch)
// Analog NOT PRESSED = 249; (touch as potentiometer; values are +-1)
// Analog PRESSED     = 5; (touch as potentiometer; values are +-1)
jmp1  = 0: motor 1 flipped
jmp2  = 0: motor 2 flipped
jmp3  = 0: motor 3 flipped
jmp4  = 0: motor 4 flipped
jmp5  = 0: motor 5 flipped
jmp6  = 0: motor 6 flipped
jmp7  = 0: motor 7 flipped
jmp8  = 0: motor 8 flipped
jmp9  = 0: motor 9 flipped
jmp10 = 0: motor 10 flipped
jmp11 = 0 && jmp12 = 0: Single Driver TANK
jmp11 = 1 && jmp12 = 0: Dual Driver   TANK
jmp11 = 0 && jmp12 = 1: Single Driver ARCADE
jmp11 = 1 && jmp12 = 1: Dual Driver   ARCADE
ana1  < 200: motor 6 IGNORE CCW
ana2  < 200: motor 6 IGNORE CW
ana3  < 200: motor 7 IGNORE CCW
ana4  < 200: motor 7 IGNORE CW
ana5  < 200: motor 8 IGNORE CCW
ana6  < 200: motor 8 IGNORE CW
ana7  < 200: motor 9 IGNORE CCW
ana8  < 200: motor 9 IGNORE CW
task main()
  int ana_1 = 0;
  int ana_2 = 0;
  int ana_3 = 0;
  int ana_4 = 0;
  int ana_5 = 0;
  int ana_6 = 0;
  int ana_7 = 0;
  int ana_8 = 0;
  while(true)
    //GLOBAL CHANGES & CHECKS:
    bMotorReflected[LeftDrive1]   = (bool)SensorValue[jmp1];
    bMotorReflected[LeftDrive2]   = (bool)SensorValue[jmp2];
    bMotorReflected[LeftDrive3]   = (bool)SensorValue[jmp3];
    bMotorReflected[RightDrive4]  = (bool)SensorValue[jmp4];
    bMotorReflected[RightDrive5]  = (bool)SensorValue[jmp5];
    bMotorReflected[Mech1]        = (bool)SensorValue[jmp6];
    bMotorReflected[Mech2]        = (bool)SensorValue[jmp7];
    bMotorReflected[Mech3]        = (bool)SensorValue[jmp8];
    bMotorReflected[Mech4]        = (bool)SensorValue[jmp9];
    bMotorReflected[RightDrive10] = (bool)SensorValue[jmp10];
    if(SensorValue[ana1] < 200)
      ana_1 = 0;
    else
      ana_1 = 1;
    if(SensorValue[ana2] < 200)
      ana_2 = 0;
    else
      ana_2 = 1;
    if(SensorValue[ana3] < 200)
      ana_3 = 0;
    else
      ana_3 = 1;
    if(SensorValue[ana4] < 200)
      ana_4 = 0;
    else
      ana_4 = 1;
    if(SensorValue[jmp11] == 0 && SensorValue[jmp12] == 0)      // if !jmp11 && !jmp12:----------------| SINGLE DRIVER - TANK |----------------------------------------
      if(SensorValue[ana5] < 200)
        ana_5 = 0;
      else
        ana_5 = 1;
      if(SensorValue[ana6] < 200)
        ana_6 = 0;
      else
        ana_6 = 1;
      if(SensorValue[ana7] < 200)
        ana_7 = 0;
      else
        ana_7 = 1;
      if(SensorValue[ana8] < 200)
        ana_8 = 0;
      else
        ana_8 = 1;
      motor[LeftDrive1]   = vexRT[Ch3];       // up = CW
      motor[LeftDrive2]   = vexRT[Ch3];       // up = CW
      motor[LeftDrive3]   = vexRT[Ch3];       // up = CW
      motor[RightDrive4]  = -vexRT[Ch2];      // up = CCW
      motor[RightDrive5]  = -vexRT[Ch2];      // up = CCW
      motor[Mech1]        = ((vexRT[Btn5U] * 127) * ana_2) - ((vexRT[Btn5D] * 127) * ana_1);   // U = CW, D = CCW
      motor[Mech2]        = ((vexRT[Btn6U] * 127) * ana_4) - ((vexRT[Btn6D] * 127) * ana_3);   // U = CW, D = CCW
      motor[Mech3]        = ((vexRT[Btn7U] * 127) * ana_6) - ((vexRT[Btn7D] * 127) * ana_5);   // U = CW, D = CCW
      motor[Mech4]        = ((vexRT[Btn8U] * 127) * ana_8) - ((vexRT[Btn8D] * 127) * ana_7);   // U = CW, D = CCW
      motor[RightDrive10] = -vexRT[Ch2];        // up = CCW
    // if jmp11 && !jmp12:----------------------| DUAL DRIVER - TANK |-----------------------------------------------------------------------------------------------------
    else if(SensorValue[jmp11] == 1 && SensorValue[jmp12] == 0)
      motor[Mech1]        = ((vexRT[Btn5UXmtr2] * 127) * ana_2) - ((vexRT[Btn5DXmtr2] * 127) * ana_1);   // U = CW, D = CCW
      motor[Mech2]        = ((vexRT[Btn6UXmtr2] * 127) * ana_4) - ((vexRT[Btn6DXmtr2] * 127) * ana_3);   // U = CW, D = CCW
      if((SensorValue[ana_6] < 200 && vexRT[Ch3Xmtr2] > 0) || (SensorValue[ana_5] < 200 && vexRT[Ch3Xmtr2] < 0))
        motor[Mech3]        = 0;
      else
        motor[Mech3]        = vexRT[Ch3Xmtr2];  // up = CW
      if((SensorValue[ana_8] < 200 && vexRT[Ch2Xmtr2] > 0) || (SensorValue[ana_7] < 200 && vexRT[Ch2Xmtr2] < 0))
        motor[Mech4]        = 0;
      else
        motor[Mech4]        = (vexRT[Ch2Xmtr2]);  // up = CW
    else if(SensorValue[jmp11] == 0 && SensorValue[jmp12] == 1)    // if !jmp11 && jmp12:---------------------| SINGLE DRIVER - ARCADE |-------------------------------------
      motor[LeftDrive1]   = vexRT[Ch1] + vexRT[Ch2];       // up = CW, right = CW
      motor[LeftDrive2]   = vexRT[Ch1] + vexRT[Ch2];       // up = CW, right = CW
      motor[LeftDrive3]   = vexRT[Ch1] + vexRT[Ch2];       // up = CW, right = CW
      motor[RightDrive4]  = vexRT[Ch1] - vexRT[Ch2];       // up = CW, right = CCW
      motor[RightDrive5]  = vexRT[Ch1] - vexRT[Ch2];       // up = CW, right = CCW
      if((SensorValue[ana_6] < 200 && vexRT[Ch3] > 0) || (SensorValue[ana_5] < 200 && vexRT[Ch3] < 0))
        motor[Mech3]        = 0;
      else
        motor[Mech3]        = vexRT[Ch3];  // up = CW
      if((SensorValue[ana_8] < 200 && (-vexRT[Ch4]) > 0) || (SensorValue[ana_7] < 200 && (-vexRT[Ch4]) < 0))
        motor[Mech4]        = 0;
      else
        motor[Mech4]        = (-vexRT[Ch4]);  // right = CCW
      motor[RightDrive10] = vexRT[Ch1] - vexRT[Ch2];       // up = CW, right = CCW
    else if(SensorValue[jmp11] == 1 && SensorValue[jmp12] == 1)    // if jmp11 && jmp12:---------------------| DUAL DRIVER - ARCADE |--------------------------------------
        motor[Mech3]        = 0;
      else
        motor[Mech4]        = 0;
      else
