Two new products have just been added to the VEX Website.
First up, is a 10-Pack of Low Profile, High Strength, Clamping Shaft Collars. For those wondering, these are half the width of the existing High Strength Shaft Collars, and have a smaller effective diameter.
How do those sleeve washers not add additional functionality from standard Vex components? Just because it has washer in the description does not make it legal. As a ref inspecting robotis, I would not pass those.
It doesn’t because you could turn down an (almost) identical part out of Vex’s nylon spacers on a lathe, and you could get a perfectly identical part if you used 3rd party spacers with a smaller hole as the vex spacers have quite a bit of slop in them.
This sensor can be used to know your robot’s location on the field at all times, and can be used to aid in programming advanced autonomous routines. We especially can’t wait to see how this sensor raises the level of the Programming Skills Competition!
I think the sensor has an unfortunate name. To all of us GPS stands for Global Positioning System. It’s a system that uses a set of satellites and some fancy math for the receiver to be able to locate within a 16’ circle.
The Vex sensor uses the coded strips on the wall to figure out the position of the robot using a vision sensor.
Maybe a better name is VPS visual position sensor, or Vex Position Sensor. RPS for Robot?
They should either make it illegal, or required. It could give a team an advantage or a disadvantage if some field their code just wouldn’t work on, but others it would be superior
