Programming VEX Cortex clawbot
So I recently salvaged this old VEX claw-bot, and I had to wipe the programming because it went rouge. Can someone please guide me through ROBOTC? I have no idea what i’m doing and I don’t know how to reprogram this metal demon :joy:
Here’s a simple code to get you started :slight_smile:
while(true){
//Button presses
if(vexRT[Btn5U] == 1){
motor[arm] = 127; // Full forward
else if(vexRT[Btn5D] == 1){
motor[arm] = -127; // Full backward
else{
motor[arm] = 0; //Stop
//Simple Arcade:
motor[leftMotor1]  = vexRT[Ch2] + vexRT[Ch1];
motor[leftMotor2]  = vexRT[Ch2] + vexRT[Ch1];
motor[rightMotor1] = vexRT[Ch2] - vexRT[Ch1];
motor[rightMotor2] = vexRT[Ch2] - vexRT[Ch1];
For motors and sensors setup, you add the default green motors as 393’s, no IME’s or whatever since regular 393’s are not “intelligent.” Controller doesn’t need to be added to the motors and sensors setup.
Thank you so much! I’ll try to recode it this weekend.
