Question of the day
I know the answer already, just putting it out there for some to guess. I’ll post the answer here later today. Price is Right rules, I’ll contact and mail the closest guess some stickers.
Working on acquiring a storage cart for our extra field perimeters and needed to know the weight. How much does an EDR field perimeter weigh?
Guesses in pounds or kilos
Am I allowed to play?
227 lbs
EDIT: this is assuming you include all the brackets and other hardware.
I’ll guess 200 lbs even.
knowing vex, 250 lb +/- 50 lb
6318 lbs
174 lbs
169 pounds
I believe its around 220 kg (Around 480 pounds)
270lb
20 characters 20
245 pounds
one and a half duck ponds
Approx 0 pounds rounding to the nearest 1000 tons
87 pounds, but jon rogers’ robot weighs more
215 lbs
219 lbs
Since you didn’t specify other conditions of the experiment, I choose to report weight in the deep space which is exactly 0 lbf.
But, if you assume the surface of planet Earth, I would guess 263 lb.
257 lbs
20 characters
gravity do be pulling from everywhere tho
