SD Card Brain Image not working
I have a file called BRAIN_IMAGE.png in the sd card of my Vex V5 Brain
However when I use this line of code to display it:
brain.screen.draw_image_from_file('BRAIN_IMAGE.png', 0, 0)
It doesn’t display it and there is no error.
Could someone suggest why this might be?
Thanks
SuhJae made a converter to make the image uploadable directly through the project file. I suggest using that.
Thats is only for c++. I am using python. Also, their solution makes the project file much larger for no reason since the sd card should work since I have one.
Don’t use uppercase.
brain.screen.draw_image_from_file('brain_image.png',0,0)
No idea why, probably some limitation of the embedded file system.
Thanks for you help. I thought it would be something odd lile that
