You mean 60:12, always put driving gear first
I got an idea, hear me out:
- Regular x-drive or 4 wheel omni tank
- Intake covering the entire front, preferably with two pistons that can raise it
- Intake can be used to turn colored rollers
- Turnable shooter, hole in bottom for loading
- Intake feeds upward into the hole, like a tank turret
So the motor distribution would be:
- 4 for drivetrain
- 1 or 2 for intake & roller spinner
- 1 for shooter turner
- 1 or 2 for flywheel
Or do you also need a motor to feed into the shooter spinner?
yep, thatās what I was thinking. some robots from tipping pointās season could probably do that (including our teamās first one) we had an intake and weāre guessing itāll work pretty well for this too
You canāt expand past 18 inches
4m mecanum
2 piston antislipmat thrower
1m flywheel
1m intake+roller spinner
1m turret
1m feeder
I might be able to use a pneumatic feeder if I use pressure regulartor for 60 actuations so I can get an extra motor for controlling angle.
I see more teams early season going 4m tank, and then as motor sharing develops weāll see more complex subsystems with 6m drives.
i think the meta with a 6m drive will be a 1m intake and 1m flywheel
but no clue how pistons will make too much sense
yes same difference lol
Pneumatic brake for shooting so ppl cant push u, also expansion at the end.
makes sense
but the brake would have to cleverly engineered so as not to break the actual piston
and only use it for retraction and extension
Just donāt use the piston for structure
So do single acting pistons use less air then double acting pistons?
Same amount of air when extending, but the DA cylinders use air to both extend and retract so yes the SA cylinders use a bit less air.
Best practice is to not assume other folks use the same convention as you do, and clearly label your ratios. Especially when the conversation includes a diverse population of students at a variety of ages, across multiple countries.
Fact of the matter is that it depends what youāre aiming to express (torque v speed) and then what youāre using as your inputs. Different industries and professions have different conventions.
Check out this entire discussion on the issue.
Edit to add, this official document from Vex about how to use gear ratios sometimes has the driven gear first - https://kb.vex.com/hc/en-us/articles/360035590932-Using-Gear-Ratios-with-the-V5-Motor
The feeder could be done with pneumatics without much difficulty
im thinking
4 motor mecanum drive
1/2 motor flywheel
1/2 motor intake
1 motor roller
pneumatic expansion
also, my team is not too experienced, so we cant do odometry or something fancy like that. How would we be able to write a code to aim for the high goal?
Donāt use mecanums for this game, if you want strafing, do an x-drive (I also donāt think strafing is necessary for a low level team)
Probably vision sensor
What if we have āNo Sensors?ā ![]()
