My team has recently finished most of our bot and is now working on fine tuning and adding smaller functions. We want to add a fishing line or tape measure mechanism (not sure which its called in most places) and aren’t sure how to power it. We know how to build the mechanism but don’t know how to power it without tangling our bot up with string.
Hello!
I would recommend using a slightly different mechanism to achieve the same thing. It doesn’t need to be powered and is fast and easy to make.
It’s shown here,
(The second “feature”)
But, if you are set on a mechanism using string then YouTube is gonna be your best resource
We have built that feature before and used it effectively, but we wanted one that could be used for both skills, china load, and any other start configuration we might need. Do you know how to build the mechanism described above?
YouTube is probably gonna help you the most,
after a quick search I couldn’t find much, unless you’re looking for a wall-rider type mechanism for a china load (https://youtube.com/shorts/vbYIb-Cbnlo?si=CAP9BvxpNoW0kXwI)
you can probably find more with a more thorough search
Make a wind-up mechanism for your string that sucks the string into your bot. Then have a gear that holds it so it can’t wind. THEN move the pneumatic that pulls the gear off.
the mechanism ive seem most teams use is powered by a tightly wound rubber band, not a motor, the only thing the motor does is remove the ratchet, and i was hoping somebody who had built the mech before could tell me how they moved the ratchet. All that is required is a tiny bit of power to remove the ratchet for a second.
This should be an example of the mechanism but it doesn’t show how to activate the mechanism.
This is the “head-start”. It is pretty self explanatory and it will retract once it leaves the side wall. Attach it to the side of your bot and you’re good to go.
This is the mechanism that Joeboticswastaken was talking about, and my team has taken full advantage of it at all of our competitions prior to worlds, but we have seen some advanced teams use the fishing line and like how its so adjustable, unlike the headstart. We know how to build the entire thing, using a 5:1 ratio and a wind up string, but we don’t know how to remove the ratchet. Most people we have seen somehow use the intake to pull the ratchet at the start of the match, but none of the videos we have found have explained how they do this.
Hi there- we’re the ones who made that video and we intentionally didn’t give the full functioning mechanism so that people could explore the idea, but I’ve seen a lot of good ways people have done it.
Keep in mind that the pawl here doesn’t need a rubber band to keep it to the ratchet gear- the spool trying to wind back up holds it in at the start, and then anything that spins on a shaft could hit it and knock it out of the way.
Here’s an example of a simpler version . This could be mounted horizontally (so like, you’re looking down at this from above) and then any shaft that’s spinning (like for an intake mechanism) could have a locking beam on it that would hit the standoff extender and knock it just a bit out of the way at the start.
This shows it from the side- rubber band just goes through a hold and the axle goes through it between the sprockets. Wind the string all the way, then attach the rubber band. Then pull it out and set the pawl.
A simpler version but one that might put more friction on your system us in this video- look at about 2:50 and you’ll see how they attach it to an intake axle.
Thank you so much, I will try this out tomorrow (I’m at home now, can’t go back to school :)) at club. I have most of the mech built and installed, so I’ll work on that final bit and the bot will be done. Yay!
I built one, all you do is wrap the band around the gear. the way the “spring” releases is when your robot runs into something. (or accelerate quickly, its all about the G’s)
