Let’s start a thread celebrating the stupidity of ourselves.
This thread is not to pick on others about what they have done, merely just for humor.
I’ll start. Yesterday I spent 5 minutes trying to put a nut on a screw before I realized that I was turning the screw the wrong way.
I then proceeded to do it again later on…
Someone in my team once filled a motor screw hole with the wrong loctite, the stuff that you need explosives to get off, and then put a screw in it.
Had to angle grind off screw . The screw lost
Either deciding to rebuild the week before states rookie year or putting the 35 pound steel cube (with unfolding ramp) on the top shelf in the storage closet. It wasn’t my robot, it was my sister team’s. They had a fun time getting it down.
Oh, boy, that’s going to be a long list for me. I have to say that my dumbest mistake was gearing motors 7:1 together on a flywheel at the beginning of this season. I also built an intake to score into the low goal, but the top of the intake was about an inch too low to make it over the bar.
Easily the stupidest thing I’ve done is from my rookie year when I built a two motor tank drive. And when I say tank drive I mean using the tank treads so it looked like an actual tank. I couldn’t figure out why it wouldn’t drive for very long. That thing would’ve overheated with four motors.
I don’t know how stupid this is, but we like to fill up the ends of screwdrivers with washers (and wonder where all of our washers went, but that’s beside the point). We stand them up without the ends on. After a few hours one of us forgets it’s filled with washers and picks it up. Fun
Putting on the motors for the drive train backwards
And then taking them off to put them on the wrong side
And then taking them off to put them on the wrong place
And then taking them off to put them in the same place again
…It’s happened so many times.
I went a whole competition where every match me and my teammates forgot to plug our power expander in for our launcher. +1 To that comment about having to grind off screws because of the wrong loctight.
Realize you screwed something into the wrong holes/backwards, take it off, then absentmindedly proceed to reattach it in the exact same place, repeat . . .
At the beginning of the season one of our teams used a joystick to slowly speed up the motors to test out their flywheel. Whey they finished with the test the student dumped it into reverse and parts exploded out of the robot. It was a good lesson in inertia.
I’m not gonna mention any teams specifically, but in last year season, i put way too much faith in other teams ability to do skyrises. Other that that, is just the usual:
Forgetting to plug in the battery
Forgetting to plug in the cortex
Not putting the clips in for the sensor side of my cortex
Building a scissor lift based in those turntable things
Overtightened collars then stepping therm
Buying a bunch of the shortest 832 screws
Not drinking enough water during a completion
Not bringing a pump to world’s last year
Also, that point in robotc when you compile and it gets you to save, but you don’t know what it’s trying to get you to save so you call it the same name as the file your working on and it overrides it and you lose all your code.
