Any Ideas on how to use a lift for picking up the risers. I was thinking that we can have two lifts on the sides and that will pick up the risers. If you guys have any ideas plz tell me because I have troubles creating something for picking up the risers using an elevator. I created a arm for the risers. If you want to see it go check out my YouTube channel. It is called Supreme VexIq.
Please use the search bar before creating a new topic. I would suggest using a Double Reverse Four Bar, as mentioned several times in the thread above.
you could a cascade lift, a sixbar/8bar, rack lift and if you are good enough a revers 4,6 or 8 bar.
