K, so here is my great idea. First off, VEX would have to release new flipper parts, but aside from that here it is. So the field is circular, and has two levels. in the center of the field is a tank of water that extends up to the second level. There is a ramp on the outer edge of the field to get to the top. Or if you wanted an extra challenge you could try to go up the water tank. Anyway, so on each level there are 4 water stations. One is in the middle of the tank and the others are spaced evenly on the edges. The one in the middle would dispense more water than the ones on the edge. (There would be an expansion limit, so you would be forced to swim.) On each level there are 7 water storages. They would be placed as follows; three small tanks would be directly across from the small capacity water dispensers. They would give 5 points for each cup of water in them, then there would be three above those which would give 7 points for each cup, and finally there would be one storage at the bottom of the tank of water. This would give 15 points for each cup in it, but would be the hardest to get to. On top of each storage, there would be a red and blue flag. Whichever side is showing, that is the team that gets the amount of points for how much water was in the thing.
