Use a glue gun to fill in those air vents on the motors and brain to water proof your bot!
There is something that is called a screw, don’t use those on your robot because it will ‘screw’ the performance and it is not a secure joint. You should use tape instead to connect metal pieces together. Tape connects everything!
Which is the Zelda from BOTW, and which is the Zelda from OOT?
If you’re building, even though tape is good, you should use glue. Glue is the best connector for everything! What type of glue you may ask? You should use gluesticks, but spreading a very very thin layer of glue from bottles is okay too.
though srsly pls don’t
If u steal the tournament champion trophy from the winning team, u become the new tournament champion and can qualify for states/worlds.
Wait a minute. But I actually do that sometimes. Uh oh
You’re only breaking the rules if you get caught
That’s good advice for anything anywhere.
If you are bored and want to post on the forum, your best post is a poll. And the second best post is replying to that poll with another poll ![]()
Not gonna lie, that will most likely last you 3 matches in a row.
but you know, just to be safe or something
If ur motors aren’t working, spray the brain with compressed air. It’s probably overheated and can’t send power to the motors
leave a bin of vex parts out in the middle of the floor, so that when you try to step over them you tear off your toenail.
ill do you one better leave your robot at the foot of your bed and forget about it so you trip and cut up your leg when you get up and almost have to go to the hospital
Wow. My worst robotics injuries have been hitting by hand on the door when walking in with the robot’s huge box and cutting myself on a tape dispenser at like 11:30 before a tournament.
literally every highschool team ever
In our experience they last about 1-2 matches
Nylocks are useless and just weigh your bot down
Nylocks are too hard to put on. Don’t even try to use them. (me in middle school)
