According to the rule SG10 which says
** Robots may not contact the opposing Alliance’s 10 Point Zone or 20 Point Zone**
and then the rule G13 which says
** * Intentional strategies causing an opponent to violate a rule are not permitted, and will not result in an infraction on the opposing alliance.***
would a team that is between an opposing robot and the opposing teams 10 point bar and is subsequently pushed into the bar be disqualified. Would the team that pushes them be intentionally be forcing them to break a rule and would the team that is pushed be counted as forcing the pushing robot to break a rule (G13) due to them blocking as the team does not have to push them. Does the intent to score a goal count as a factor. Also will a robot that is accidentally entangled to an opposing robot be penalized for touching the opposing 10 point bar if they are pulled into it by the opposing robot. Finally will being pushed into scoring objects that are touching the ten point zone count due to the rule SG15
** Scoring Objects cannot be used to accomplish actions that would be otherwise illegal if they were attempted by Robot mechanisms.** *
I have provided pictures of the first scenario below with red and blue robots as squares with arrows showing the direction they are trying to move.
Thank You For Your Time in answering these questions.
-Jacob
First, the definition of 10 Point Zone is as follows, with a portion bolded for emphasis:
The scenario that you are describing, where a defender contacts an opposing alliance’s Starting Bar, is completely legal, regardless if they were pushed into it or not.
For information regarding what to do when a robot is pushed into the 10 Point Zone, please see the following posts and the Q&A Summary:
To be clear, because contacting an opponent’s Starting Bar is legal, we’re going to assume that you are referring to a blue robot (using your images) being pulled into the red 10 Point Zone. This situation would be extremely dependent upon the context of the match. However, referees would be advised to utilize <G12> if necessary, especially the portion quoted and bolded below:
So, the defender (blue) would likely be in violation, via <SG10> and <G12>. In general, teams should exercise caution when attempting a defensive strategy that could put them in a position which violates <SG10>.
It is difficult to provide a blanket ruling based off of a hypothetical scenario, but likely, yes. <G2> (“common sense always applies in the VEX Robotics Competition”) should be used to interpret these scenarios. For example, a defender who is planted on a Scoring Object in the 10 Point Zone would be considered in violation of <SG10> via <SG15>. However, a robot who incidentally contacts a row of Cones that happen to transitively lead back to the opponent’s 20 Point Zone (https://i.imgur.com/qFzUcce.png) would not be in violation.
