VexCode pro v5 Pneumatics
We are trying to figure how to manage to have 2 pneumatics in our system. This code seems to work with 1 pneumatic in the code, but once we add the second pneumatic it doesn’t work. We have tried a new brain, new solenoid, new driver, everything, and it has fixed nothing. So the problem must be in the code.
#include "vex.h"
using namespace vex;
bool open=true;
void Clamp1()
 open=!open;
bool open1=true;
void Clamp2()
 open1=!open1;
int main() {
   vexcodeInit();
 digital_out pneumatic1 = digital_out(Brain.ThreeWirePort.A);
 digital_out pneumatic = digital_out(Brain.ThreeWirePort.C);
  Controller1.ButtonL1.pressed(Clamp1);
 if (open==true)
   pneumatic.set(true);
 else {
   pneumatic.set(false);
 Controller1.ButtonR1.pressed(Clamp2);
 if (open1==true)
   pneumatic1.set(true);
 else {
   pneumatic1.set(false);
Any suggestions on how to fix this issue would be greatly appreciated.
edit: code tags fixed by mods.
So, I actually was having issues with this earlier. The way someone else helped me fix it was
void PneumaticToggle(){
      pneumatic.set(!pneumaticValue)
void Pneumatic1Toggle(){
      pneumatic1.set(!pneumatic1Value)
Then in the driver code you would just have
Controller1.ButtonA.pressed(PneumaticToggle);
Controller1.ButtonB.pressed(Pneumatic1Toggle);
also, if they are linked together you can do a splitter.
edit: credit for that fix goes to @xTigr, he was the one who showed it to me
