rpm
December 28, 2019, 12:03am
1
I responded in a couple other topics about Arcade and X-Arcade drive code. I had intended to post some tables to visualize what is happening in the code but discourse does not make that easy. So I converted a spreadsheet to HTML & JavaScript. You can pull or download the html pages from GitHub here:
BTW, I’m sure I didn’t come up with the Arcade Drive equations. I remember seeing something like them a few years(?) back but it still took me a couple hours to figure out the math. If anyone knows who first came up with this please post (I didn’t see anything in my search).
Disclaimer: X-Arcade has not been tested on an actual robot, yet.
rpm
January 26, 2020, 1:32am
2
Well I found out how to add tables so I figured I’d put the Arcade drive equation here with the tables showing some values for different joystick positions. The X-Arcade tables are interactive so they are still in HTML form found at the github link above.
If using joy and/or motor ranges that are not -127 to 127 then the 127 in the equations changes to the joy value and the output value must be scaled to the motor range.
Arcade Drive Equations
Extrapolated from Arcade function
These equations are for Left Drive is normal and Right Drive is reversed
mSpeed is the Forward (and -Reverse) vector component due to Speed
mYaw is the Left (and -Right) vector component due to Yaw
mSpeed = Speed - (Speed*ABS(Yaw)/127)/2
mYaw = Yaw - (Yaw*ABS(Speed)/127)/2
L = mSpeed + mYaw
R = mSpeed - mYawm
mSpeed Values
null
-127
-112
-96
-80
-64
-48
-32
-16
0
16
32
48
64
80
96
112
127
127
63.5
71
79
87
95
103
111
119
127
119
111
103
95
87
79
71
63.5
112
56
62.5
69.5
76.5
84
91
98
105
112
105
98
91
84
76.5
69.5
62.5
56
96
48
53.5
59.5
66
72
78
84
90
96
90
84
78
72
66
59.5
53.5
48
80
40
44.5
50
55
60
65
70
75
80
75
70
65
60
55
50
44.5
40
64
32
36
40
44
48
52
56
60
64
60
56
52
48
44
40
36
32
48
24
27
30
33
36
39
42
45
48
45
42
39
36
33
30
27
24
32
16
18
20
22
24
26
28
30
32
30
28
26
24
22
20
18
16
16
8
9
10
11
12
13
14
15
16
15
14
13
12
11
10
9
8
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
-16
-8
-9
-10
-11
-12
-13
-14
-15
-16
-15
-14
-13
-12
-11
-10
-9
-8
-32
-16
-18
-20
-22
-24
-26
-28
-30
-32
-30
-28
-26
-24
-22
-20
-18
-16
-48
-24
-27
-30
-33
-36
-39
-42
-45
-48
-45
-42
-39
-36
-33
-30
-27
-24
-64
-32
-36
-40
-44
-48
-52
-56
-60
-64
-60
-56
-52
-48
-44
-40
-36
-32
-80
-40
-44.5
-50
-55
-60
-65
-70
-75
-80
-75
-70
-65
-60
-55
-50
-44.5
-40
-96
-48
-53.5
-59.5
-66
-72
-78
-84
-90
-96
-90
-84
-78
-72
-66
-59.5
-53.5
-48
-112
-56
-62.5
-69.5
-76.5
-84
-91
-98
-105
-112
-105
-98
-91
-84
-76.5
-69.5
-62.5
-56
-127
-63.5
-71
-79
-87
-95
-103
-111
-119
-127
-119
-111
-103
-95
-87
-79
-71
-63.5
mYaw Values
null
-127
-112
-96
-80
-64
-48
-32
-16
0
16
32
48
64
80
96
112
127
127
-63.5
-56
-48
-40
-32
-24
-16
-8
0
8
16
24
32
40
48
56
63.5
112
-71
-62.5
-53.5
-44.5
-36
-27
-18
-9
0
9
18
27
36
44.5
53.5
62.5
71
96
-79
-69.5
-59.5
-50
-40
-30
-20
-10
0
10
20
30
40
50
59.5
69.5
79
80
-87
-76.5
-66
-55
-44
-33
-22
-11
0
11
22
33
44
55
66
76.5
87
64
-95
-84
-72
-60
-48
-36
-24
-12
0
12
24
36
48
60
72
84
95
48
-103
-91
-78
-65
-52
-39
-26
-13
0
13
26
39
52
65
78
91
103
32
-111
-98
-84
-70
-56
-42
-28
-14
0
14
28
42
56
70
84
98
111
16
-119
-105
-90
-75
-60
-45
-30
-15
0
15
30
45
60
75
90
105
119
0
-127
-112
-96
-80
-64
-48
-32
-16
0
16
32
48
64
80
96
112
127
-16
-119
-105
-90
-75
-60
-45
-30
-15
0
15
30
45
60
75
90
105
119
-32
-111
-98
-84
-70
-56
-42
-28
-14
0
14
28
42
56
70
84
98
111
-48
-103
-91
-78
-65
-52
-39
-26
-13
0
13
26
39
52
65
78
91
103
-64
-95
-84
-72
-60
-48
-36
-24
-12
0
12
24
36
48
60
72
84
95
-80
-87
-76.5
-66
-55
-44
-33
-22
-11
0
11
22
33
44
55
66
76.5
87
-96
-79
-69.5
-59.5
-50
-40
-30
-20
-10
0
10
20
30
40
50
59.5
69.5
79
-112
-71
-62.5
-53.5
-44.5
-36
-27
-18
-9
0
9
18
27
36
44.5
53.5
62.5
71
-127
-63.5
-56
-48
-40
-32
-24
-16
-8
0
8
16
24
32
40
48
56
63.5
(L,R) Drive Values
null
-127
-112
-96
-80
-64
-48
-32
-16
0
16
32
48
64
80
96
112
127
127
(0, 127)
(15, 127)
(31, 127)
(47, 127)
(63, 127)
(79, 127)
(95, 127)
(111, 127)
(127, 127)
(127, 111)
(127, 95)
(127, 79)
(127, 63)
(127, 47)
(127, 31)
(127, 15)
(127, 0)
112
(-15, 127)
(0, 125)
(16, 123)
(32, 121)
(48, 120)
(64, 118)
(80, 116)
(96, 114)
(112, 112)
(114, 96)
(116, 80)
(118, 64)
(120, 48)
(121, 32)
(123, 16)
(125, 0)
(127, -15)
96
(-31, 127)
(-16, 123)
(0, 119)
(16, 116)
(32, 112)
(48, 108)
(64, 104)
(80, 100)
(96, 96)
(100, 80)
(104, 64)
(108, 48)
(112, 32)
(116, 16)
(119, 0)
(123, -16)
(127, -31)
80
(-47, 127)
(-32, 121)
(-16, 116)
(0, 110)
(16, 104)
(32, 98)
(48, 92)
(64, 86)
(80, 80)
(86, 64)
(92, 48)
(98, 32)
(104, 16)
(110, 0)
(116, -16)
(121, -32)
(127, -47)
64
(-63, 127)
(-48, 120)
(-32, 112)
(-16, 104)
(0, 96)
(16, 88)
(32, 80)
(48, 72)
(64, 64)
(72, 48)
(80, 32)
(88, 16)
(96, 0)
(104, -16)
(112, -32)
(120, -48)
(127, -63)
48
(-79, 127)
(-64, 118)
(-48, 108)
(-32, 98)
(-16, 88)
(0, 78)
(16, 68)
(32, 58)
(48, 48)
(58, 32)
(68, 16)
(78, 0)
(88, -16)
(98, -32)
(108, -48)
(118, -64)
(127, -79)
32
(-95, 127)
(-80, 116)
(-64, 104)
(-48, 92)
(-32, 80)
(-16, 68)
(0, 56)
(16, 44)
(32, 32)
(44, 16)
(56, 0)
(68, -16)
(80, -32)
(92, -48)
(104, -64)
(116, -80)
(127, -95)
16
(-111, 127)
(-96, 114)
(-80, 100)
(-64, 86)
(-48, 72)
(-32, 58)
(-16, 44)
(0, 30)
(16, 16)
(30, 0)
(44, -16)
(58, -32)
(72, -48)
(86, -64)
(100, -80)
(114, -96)
(127, -111)
0
(-127, 127)
(-112, 112)
(-96, 96)
(-80, 80)
(-64, 64)
(-48, 48)
(-32, 32)
(-16, 16)
(0, 0)
(16, -16)
(32, -32)
(48, -48)
(64, -64)
(80, -80)
(96, -96)
(112, -112)
(127, -127)
-16
(-127, 111)
(-114, 96)
(-100, 80)
(-86, 64)
(-72, 48)
(-58, 32)
(-44, 16)
(-30, 0)
(-16, -16)
(0, -30)
(16, -44)
(32, -58)
(48, -72)
(64, -86)
(80, -100)
(96, -114)
(111, -127)
-32
(-127, 95)
(-116, 80)
(-104, 64)
(-92, 48)
(-80, 32)
(-68, 16)
(-56, 0)
(-44, -16)
(-32, -32)
(-16, -44)
(0, -56)
(16, -68)
(32, -80)
(48, -92)
(64, -104)
(80, -116)
(95, -127)
-48
(-127, 79)
(-118, 64)
(-108, 48)
(-98, 32)
(-88, 16)
(-78, 0)
(-68, -16)
(-58, -32)
(-48, -48)
(-32, -58)
(-16, -68)
(0, -78)
(16, -88)
(32, -98)
(48, -108)
(64, -118)
(79, -127)
-64
(-127, 63)
(-120, 48)
(-112, 32)
(-104, 16)
(-96, 0)
(-88, -16)
(-80, -32)
(-72, -48)
(-64, -64)
(-48, -72)
(-32, -80)
(-16, -88)
(0, -96)
(16, -104)
(32, -112)
(48, -120)
(63, -127)
-80
(-127, 47)
(-121, 32)
(-116, 16)
(-110, 0)
(-104, -16)
(-98, -32)
(-92, -48)
(-86, -64)
(-80, -80)
(-64, -86)
(-48, -92)
(-32, -98)
(-16, -104)
(0, -110)
(16, -116)
(32, -121)
(47, -127)
-96
(-127, 31)
(-123, 16)
(-119, 0)
(-116, -16)
(-112, -32)
(-108, -48)
(-104, -64)
(-100, -80)
(-96, -96)
(-80, -100)
(-64, -104)
(-48, -108)
(-32, -112)
(-16, -116)
(0, -119)
(16, -123)
(31, -127)
-112
(-127, 15)
(-125, 0)
(-123, -16)
(-121, -32)
(-120, -48)
(-118, -64)
(-116, -80)
(-114, -96)
(-112, -112)
(-96, -114)
(-80, -116)
(-64, -118)
(-48, -120)
(-32, -121)
(-16, -123)
(0, -125)
(15, -127)
-127
(-127, 0)
(-127, -15)
(-127, -31)
(-127, -47)
(-127, -63)
(-127, -79)
(-127, -95)
(-127, -111)
(-127, -127)
(-111, -127)
(-95, -127)
(-79, -127)
(-63, -127)
(-47, -127)
(-31, -127)
(-15, -127)
(0, -127)
