VEXCode Joystick Curving
Hello, today I will be discussing Joystick Curving in VEXCode, inspired by Pilons 5225A.
Example Code for VEX Clawbot:
turningCurve = 5;
turningRed = false;
forwardCurve = 10;
forwardRed = false;
//graph of red and blue lines from 5225A here
//https://www.desmos.com/calculator/sdcgzah5ya
int curveJoystick(bool red, int input, double t){
  int val = 0;
  if(red){
    val = (std::exp(-t/10)+std::exp((std::abs(input)-100)/10)*(1-std::exp(-t/10))) * input;
  }else{
    //blue
    val = std::exp(((std::abs(input)-100)*t)/1000) * input;
  return val;
void usercontrol(void) {
  while(1){
    double turnVal = curveJoystick(false, Controller1.Axis1.position(percent), turningCurve); //Get curvature according to settings [-100,100]
    double forwardVal = curveJoystick(false, Controller1.Axis3.position(percent), forwardCurve); //Get curvature according to settings [-100,100]
    double turnVolts = turnVal * 0.12; //Converts to voltage
    double forwardVolts = forwardVal * 0.12; //Converts to voltage
    LeftMotor.spin(forward, forwardVolts + turnVolts, voltageUnits::volt); //Apply Via Voltage
    RightMotor.spin(forward, forwardVolts - turnVolts, voltageUnits::volt);
    vex::task::sleep(20);
To figure out what values to add, go to this demos that was once originated by Pilons, but which I modified for VEXCode usage: VEXCode Graph
There are two types of curves, a red and a blue curve. To utilize a blue curve, put "turningRed " or "turningRed " false. Otherwise put it as true. There’s a slider for t in the demos graph. If you’re comfortable with the t value, set it as the value of "turningCurve " or "forwardCurve "
If you need any clarification, let me know. Bear in mind, on the top of your main.cpp code where the includes are, you may need to add #include <cmath> to be able to use std::exp and std::abs.
Enjoy :slight_smile:
I want to provide a bit of updates to the recent post.
replace these to:
Apparently I just set them as false, although they are meant to send the variables of forwardRed and turningRed into the function rather than mere values.
did you mean to say “turningRed” or “forwardRed”?
Can you elaborate on what joystick curving is?
