Reserved for discussion of VEX Sprockets, chain, and specialized chain links
Reserved for discussion of linear sliders and related hardware
Reserved for discussion of elastics, rubber banding techniques, and links to appropriate topics
I have direct experience with all types of alliance and the platinum crepe bands.
Get the platinum crepe. They are leagues better and almost never break. Only reason I would not recommend them is if s very precise amount of banding is needed or you want weak bands, and they are nearly twice as strong as alliance.
Rubber Banding Resources:
See the rest of @therealcedz UTRBs post... Most teams use this sort of rubber band system on their lift (4 bar, 6 bar, 8 bar, etc.):
<a href="http://i.imgur.com/EOkMWQx.png" rel="noopener nofollow ugc">[image]</a>
This system is great due to complexity vs. effectiveness. Just by putting a couple of pieces of metal (in this case, standoffs and screws) and rubber bands, the stress on the motors is greatly reduced.
However, some of y…
Hello! Our team was recently at a competition, and another team that we were alliance parters with told us that the rubber bands we used were not allowed since they were latex based. They said that we could only use non latex based rubber bands. Is this true? I haven’t found anything in the rules stating that they are not legal. They are size #64
Reserved for discussion of VRC legal plastics
This is a spin-off thread from this 3D pringing thread which resulted in a fairly lengthy conversation on why Lexan should be deemed as a non-usable resource from @Sylvie . I have simply moved it over to a new thread to prevent the old one from being heavily derailed.
Reserved for discussion of string, winches and any related topics
Reserved for discussion of ratchets
Reserved for discussion of worm gears, u-joints, and other odd mechanical components
Reserved for discussion of additional mechanical component 1
Reserved for discussion of additional mechanical component 2
Reserved for discussion of transmissions
Transmissions, commonly involve principles similar to that of a PTO, albiet within the same mechanism (usualy a 2-speed drivetrain).
One pneumatic actuator pushes a set of gears between two settings, causing the mesh between the gears to be modified.
The cylinders shift states between two interlocking gear ratios. This works by sliding a gear (typically beveled) in between two different gear ratios to accomplish different speeds.
Here are two videos of transmissions:
[Green Egg Robotics (Team 44), Fred VI's Sack Attack Transmission]
This video uses a motor to shift between gears, but this can be easily done with pneumatics.
[VEX Transmission]
A pto is different, and it uses cylinders to shift motor power between tw…
Reserved for additional advanced building technique 1
Reserved for additional advanced building technique 2
Reserved for additional advanced building technique 3
Reserved for discussion of Pneumatic components 1
Old Pneumatic Components
SMC parts list:
https://kb.vex.com/hc/en-us/articles/17984679227156-Legal-Pneumatics-for-Use-in-the-VEX-Robotics-Competition-VRC
Important: VEX discontinued the pneumatic solendoid cables, a part only produced by VEX
New Pneumatic Components
Reserved for discussion of lubrication of mechanical components
What do you find is the best type of grease for vex gears. Is it graphite powder, white lithium grease, WD - 40 etc.
Reserved for discussion of mechanical maintenance of V5 smart motors
DO NOT use industrial lubricants like WD-40 or white lithium grease on internal plastic gears inside V5 motors or cartridges.
You may use light synthetic oil or synthetic grease like SW-92SA that is used for fine/plastic mechanical internals of cameras, printers, keyboards, dvd players, etc…
Broken Motor Inserts - #26 by technik3k
V5 motor Cap and Threaded Insert replacement parts are sold separately
May need to be moved into V5 Motor electric/programming entry:
vexos 1.0.9 uses a different algorithm than versions 1.0.8 and earlier.
8 or less motors are still capped at 2.5A.
9 or more are capped as follow, remember this is current at the motor not current from the battery,
9 2.39A
10 2.29A
11 2.20A
12 2.12A
13 2.04A
14 1.98A
15 1.91A
16 1.85A
17 1.80A
18 1.74A
19 1.69A
20 1.65A
However, those values are only valid if user code has not set current limit lower on one or more motors. If that has happened we take the user specified lower motor curren…
Reserved for V5 components overview
3-wire:
The issue is that the build system will not guarantee the order in which instances are created across different source files.
The instance of Brain is defined I’m assuming somewhere else such as robot-config.cpp. That means it may not have been created, and therefore the Brain.ThreeWirePort also not created, when you try to access it in your main.cpp source file. The solution is to either move
bumper LiftBumper = bumper(Brain.ThreeWirePort.A);
into the same file (and placed after) as the Br…
Specific 3-wire port numbers for dual wire sensors:
Pretty sure all programming solutions either enforce this or have documentation explaining it. For example, PROS has
Encoders must be plugged into the ADI such that the top wire
is in an odd numbered port (1, 3, 5, 7 or ‘A’, ‘C’, ‘E’, or ‘G’), and then
the bottom wire must be in the next highest port number.
Possible problem due to order of initialization of 3-wire port accessor instances:
Memory Permission Error - #2 by jpearman
Temporary workaround for 8 legacy 3-wire port limit:
Connect multiple sensors to a single port to overcome the limit of 8 legacy ports
Legacy, non competition legal components:
Using Flashlight in VCS - #4 by gbr
